Does anybody know of a way to repair a digipak dvd case? The pieces that hold the disc snapped from my box set falling off my entertainment center. Is there any way to fix/repair/replace the broken pieces??
asdf
You mean those multi holders like this one :
http://www.blankdvdsupermarket.com.au/products.php?cat=14&pg=6
In any case , it's use super glue ... or in the event that the damage is more severe ... find a replacement .
I just bought 200 of these (the 4 disc unit's) -
No, a digipak case is like...
folding cardboard label with plastic disc holders. Do you have the Lord of the Rings extended dvds? I can't find a good image to show what the type of case looks like...asdf -
I've never seen those type of pieces for sale. You could try getting a replacement case from the manufacturer, but I wouldn't hold my breath. Just get a standard multi-disc case and print your own label.
Google is your Friend -
I know what they are now ... my brother has it ... and nope ... I couldnt find them when I needed them .
But here : http://www.discmakers.com/shop/ItemDetails.aspx?ItemID=CD-020-00028&ItemConfigID= -
You could also create your own. Just cut the hub portion from an existing dvd case or remove and modify the hub portion of a cd case. Then just tape or glue it into place.
http://www.bullseyedisc.com/pack_r_g.htm
Scroll way down the page to find some peel and stick disk hubs that can be mounted anywhere. Two types, foam or clear plastic."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
iThinkYouBrokeIt...don't know the extent of damage to your set, so
have no idea as to a fix.
If it's that bad, I'd use those multi holders that Bjs posted about.
I've got a bunch of the two, three, and four holder type...I really like them.
Those little hubs look nice too...thanks for that link gadgetguy!The Devil`s always.....in the Details!
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 12:04 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 15:54 -
converting broken avi file to dvd
By dvdnewbie64 in forum Video ConversionReplies: 1Last Post: 14th Dec 2008, 19:05 -
Have I Broken My DVD Writer? Region Change!
By VideoGeekUK in forum DVD & Blu-ray WritersReplies: 8Last Post: 31st Jan 2008, 12:52 -
DVD burner Open/Close button on case is broken
By JudgeGarth in forum ComputerReplies: 15Last Post: 17th May 2007, 14:36
