I have been recording onto DVD+R discs for about a year on my LiteON LVW-1101. I am now
trying to use DVD-R discs and I get an "Invalid Disc" message. The owners manual says that both DVD+R and DVD-R are okay. Do I need to change something in the settings? I confess to being a newbie. Would much appreciate any help you can offer. Thanks.
...John
Have you tried more than one brand of DVD-R?
Have you been using a DVD lens cleaner? Most usually say they should be used after every ten hours of recording/playing.
Sometimes as simple a thing as that makes a big difference.
*EDIT:
LiteOn's website says your machine works on DVD+Rs, not "+" and "-".
http://www.liteonit.com/global/index.php?option=com_content&task=view&id=30&Itemid=78
Originally Posted by MJA
Some are dual format and take both "+" and "-".
Apparently this one isn't one of those. -
Thanks for the responses. The only reason I switched is because I found some DVD-R discs on sale. The link to the LiteOn website was most helpful. It seems to indicate that my machine does not support the DVD-R format. I was not able to find this page on their website and my owners manual is for the 1101-1105 series (the 1105 does support DVD-R). I think this is the answer to my question. Many thanks for your helpful input. This is a website I will bookmark and come back to in the future!
Regards,
John
Liteon LVW-5045 replace DVD drive, project started...
By dainova in forum DVD & Blu-ray RecordersReplies: 18Last Post: 5th Apr 2011, 06:04 -
Liteon LVW-5101
By vmelkon in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Feb 2011, 15:28 -
LITEON LVW-5045 cannot read DVD-R disks
By elfie-gow in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jan 2011, 16:58 -
Liteon LVW-5005 can’t prepare 16 X DVD-R before recording
By coody in forum DVD & Blu-ray RecordersReplies: 24Last Post: 8th Jun 2009, 14:54 -
Repairing a Liteon LVW 5001
By Toxie in forum DVD & Blu-ray RecordersReplies: 15Last Post: 19th Nov 2008, 10:49
