OK.. I made the mistake of buying a WInTV GO, now I need some help with getting some capture software to use with it, I'm not very happy with the quality of the Mpeg's using the software that came with the card. Is there any hope for me, or am I totally wasting my time.
You can use Virtual Dub (Tools Section) to capture using the Huffy codec. That should give you some decent quality. Remember though that your source video is going to be a higher quality than anything you compress. Capture avi, then convert to mpg.
Wraith
Blow me for faster replies.......
.MKV's and Win 7
By xobituaryx in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2011, 14:09 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win 7 - how to remove XP....
By kenmo in forum ComputerReplies: 10Last Post: 13th Nov 2009, 17:14 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
win rar help
By kennyjunior in forum Newbie / General discussionsReplies: 6Last Post: 11th Nov 2007, 11:55
