i am trying to convert a series of widescreen avi files into 4.3 ratio movies with the subtitles below the films. This is much easier to read than having the text over the film.
Im not sure how to add the back bars without streching the film ratio.
If i select a dvd preset this happens automatically and i get a nice 4.3 screen ratio with the subs floating below the film. But i then have to reconvert to avi or what ever...
any pointers please.
What are you doing? Taking an AVI and reencoding it, also to AVI, and adding black below, and burning the subs into the black?
If so, use the AviSynth AddBorders command to add, say, 100 pixels of black below. The AR won't change.
AddBorders(0,0,0,100)
http://www.avisynth.org.ru/docs/english/corefilters/addborders.htm
If this is for DVD, then use FitCD to get the script, and if it doesn't give you enough black below, then shift some from the top. For example, if your source AVI is 640x352, and you're going for an NTSC 4:3 DVD, FitCD gives me (with ITU resize checked):
LanczosResize(720,352,0,0,640,352)
AddBorders(0,64,0,64)
You can adjust that to give yourself 100 pixels below the movie like so:
AddBorders(0,28,0,100) -
thanks manono but im working on mac os x so none of that software will work for me and im trying to do this using ffmpegx if possible.
the secondary encoding will be for two or more films on one dvd or even simply re-encoded as avi +subs allows me to view on tv with the subs comfortably below the movie. there are a number of ways i could find this useful.
as opposed to this
need to correct Aspect Ratio by padding/adding black bars - author AVCHD
By texas1 in forum Authoring (Blu-ray)Replies: 3Last Post: 24th Nov 2011, 11:44 -
Adding black bars
By ebay in forum Video ConversionReplies: 4Last Post: 7th Aug 2010, 04:37 -
Autodesk Cleaner: adding letterbox black bars ("widescreen matte"
By sybariten in forum Video ConversionReplies: 2Last Post: 13th Mar 2008, 07:57 -
Why do some Widescreen Movies still have black bars top and bottom?
By the_importer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Dec 2007, 09:09 -
ripping widescreen without the black bars?
By curt1sw in forum DVD RippingReplies: 1Last Post: 10th May 2007, 09:37
