There's been a lot of discussion about AVI/DivX/Xvid playback on Philips DVP5960, 5140, and other brands/models of players: Does it jerk with packed bitstream? If it does, does mpeg4modifier fix it? What about GMC? What about bitrate - how high; does USB do as well as DVD? What about QPEL?
I've put together some sample files to assist people who want to check out their player's capabilities. There are 5 files:
PACKED.avi: Packed bitstream with 2 consecutive b-vops.
UNPACKED.avi: The same file unpacked using mpeg4modifier.
BITRATE.avi: Bitrate starts at 750kbps, goes to 1500, then 3000, then 4500.
GMC_TEST.avi: Starts with no GMC, then GMC with 1 warp point, then with 3.
QPELTEST.avi: Encoded with QPEL.
Warning to dial-up users: the 5 files above are zipped into one 30MB download.
The file (5960test.zip) is located at:
http://mihd.net/3ux5vw
Thanks to the people at divxtest.com for some of the files I used.
	I tested my Philips HTS 3100/12 DVD Home Theatre System. The player is the "same" as DVP 5140/12, and it played all the files without problems...
 R.
	You can also use the Divx Test CD if you can find it:
 http://divxtest.surdvd.com/sommaire.php3?lang=en
 https://rapidshare.com/#!linklist|YI3DFY|||
	Hi, fmussari,
 I'm sorry but I can't find the file anymore or I'd re-post it for you; it's been a couple of computers ago since I made it.
 Jagabo's suggestion is good, though.
	I found a direct link:
 http://www.mpeg4-players.info/download/DivX.Test.CD.v2/DivXTestCDv2.0.by.bbdoc_forum.surdvd.com.iso
 This is different than the old version I had (1.0 maybe?). It's tests more stuff and it includes high def files too.
  converting bad laser Sony DVD players into Test Pattern Signal Generators?By turnkit in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Jan 2012, 03:46
  Test .sup files?By Charmer in forum SubtitleReplies: 13Last Post: 15th Sep 2010, 00:16
  [b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30
  Why doesn't MKV files play BD PGS/sup files in software or hardware playersBy cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 13:10
  How to test MPG files for errors?By madmartian in forum Software PlayingReplies: 1Last Post: 17th Jun 2009, 15:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
