I have an MPEG-2 file I want to cut some commericals out of, but I don't want to degrade the quality by recompressing it. Is there any way I can just cut out the commercials and splice the parts of the original file together?
I tried using TMPGEnc MPEG Editor to do this, but the new file has problems stalling in playback. I have found if I set it to output the file with Constant Bit Rate video, this does not happen, but the file is twice the size of the original video. Which doesn't make sense to me, since the new video is shorter.
Try Cuttermaran.
Buy My Books -
I use VideoRedo. It's perfect and I don't think it re-encodes any frames at all.
Also, there's ProjectX.
They're both very good (no quality loss at all as it's pretty much direct stream copying) and are good with keeping audio in sync.
They take about a couple minutes for an hour length video.
PS. ProjectX is free. VideoRedo is not. -
If the mpeg stream is dvd compliant then .
Use batch demux from dvdauthorgui's website to demux the mpeg into seperate video and audio stream's .
If audio is seen as m2a , rename the extension to mpa .
If audio issue remain's it can be stripped out as wav via virtualmod .
Then converted to ac3 using besweet .
While it virtualmod , follow the guide on how to generate the the celltime's text file .
Remux using rejig , muxman ... or if you know the issue's with ifoedit , you can use it .
https://forum.videohelp.com/viewtopic.php?t=291744 ... nothing but freeware used . -
Do you know of any tutorials on using Cuttermaran? I downloaded the program and got it setup, but I can't figure out how to use the program's interface.
By the way, the video files are just MPEG2 files with MP2 audio. -
Buy My Books
MKV Recompression
By JordanConley in forum Video ConversionReplies: 5Last Post: 19th Jul 2011, 01:40 -
Need help cutting out video segments and making one video with them
By darkcyber in forum DVD RippingReplies: 2Last Post: 23rd May 2011, 17:26 -
Cutting/Adding Intros to MKV files Without Recompression? (please help)
By sonicdeth in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2011, 16:00 -
How to Edit with VD without recompression
By unkown in forum EditingReplies: 13Last Post: 26th Aug 2007, 08:34 -
Resizing Without Recompression.
By Rez. in forum DVB / IPTVReplies: 8Last Post: 2nd Aug 2007, 12:17
