whats the advantage of cdrs having black surfaces, instead of shiny silver ones ?
Memorex produces these .
It impresses the heck outta' family and friends when you give 'em one....
I know...I bought a bunch off eBay a couple years ago. (cheap)
Everyone that I've given them to, had to comment on 'em.
Outside of the Bling value...they're just about the same as regular ones I guess.
(just shows more fingerprints)The Devil`s always.....in the Details! -
I don't know what the advantage would be, my Sony still cam won't reconize them. (The pocket CD-Rs out of the coolcolors 10 pack anyways)
IS IT SUPPOSED TO SMOKE LIKE THAT? -
The quality depends on the chemical material they used to produce the CD in this case black surface has a different chemical material and has advantages over the silver surface cause it will be reliable reading if its even more scratched then a silver surfaced disk. Just imagine A BLACK HOLE ABSORBING ALL THE LIGHT IT CAN GET BUT REFLECTING AS WELL.
The original reason these were produced was for ps1 console backups ... and not for anything else ... memorex are not the only one's that produce these .
Black has no advantage over silver ... infact ... it's the other way round ... you can scratch the blaze's out of a silver disc , and it will still read ... black will not .
I've worked with such disc's since 1993 for console backup's , so I know what I'm talking about here .
All disc's are made of two component's ... the writen portion which contain's the data , and the supportive carrier ... the only difference is the dye used during the support carrier production cycle .
black scenes flicker to grey/black - Sony LCD TV
By spiritgumm in forum DVB / IPTVReplies: 7Last Post: 27th Apr 2010, 09:51 -
AVI with many black lines (may be black fields)
By jarhead104 in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2009, 07:36 -
HELP ME! Footage was Black in Render and then Turned Black in Timeline!
By GLadius of Sparta in forum EditingReplies: 4Last Post: 16th Aug 2009, 21:03 -
Need DVD Player To Play DVDrs & CDrs
By DJboutit in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Jul 2009, 16:11 -
Best Buy discontunuing (Japan) Fuji CDRs!
By progrocktv in forum MediaReplies: 14Last Post: 21st May 2007, 08:51
