Dear Sir,
i use All-In-Wonder ATI 32 MB to capture and need to upgrade it to 128 or 256 MB Pci Express but i can't find it now so i decide to buy graphic card and tv tuner to capture .
and when i go to buy the tv tuner the seller said to me that the recording quality of tv tuner is not good as All-In-Wonder .
cos i didn't try to use tv tuner before so any body try both cards All-In-Wonder and Tv Tuner can help me .
thanks for help .........
I have read plenty here that says that the All In Wonder's are the inferior product. I am happy with my tuner card. I have not tried both though...
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
The AIW is (imho) substandard for most, unless you tweak forever to get it just right.
An Hauppauge PVR will give you dvd quality, right out of the box.Cheers, Jim
My DVDLab Guides -
Look into buying a Hauppauge WinTV PVR 250 or 350 (both are internal PCI cards) or the Hauppauge WinTV PVR USB2 (which is an external USB 2.0 device).
Any of these three will give you great quality captures but do note that they only capture to MPEG-1 or MPEG-2 which means no AVI type captures.
recording 1080i from dvb-t usb tuner - best practices
By codemaster in forum DVB / IPTVReplies: 1Last Post: 15th Mar 2012, 03:10 -
TV Tuner Card recording to divX
By richdem in forum Capturing and VCRReplies: 3Last Post: 14th Jan 2010, 02:42 -
recording cable HD channels on pc tuner/capture card
By Zipbiscuit in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2009, 10:52 -
Dual tuner recording = split files in Windows Media Center Vista
By yoda313 in forum Media Center PC / MediaCentersReplies: 9Last Post: 14th Jan 2009, 02:10 -
I have a question how to get hd quality on a tuner
By sdavis in forum Capturing and VCRReplies: 5Last Post: 16th Dec 2008, 16:52
