    Jan 2007
    I have a Toshiba TV with an integrated Freeview box. I plan to buy a DVD recorder with HDD capability.
    Looking at the DVD player connection guide (Antenna to DVD recorder to TV (using aerial cable) and TV to DVD recorder (using SCART) I can't see how the DVD would be able to 'read' the digital signal.
    Will I be able to record Freeview programmes using the TV's in-built freeview decoder, or will I need to buy a DVD recorder with an inbuilt Freeview box?
    The TV has 2 scart sockets, an S-Video connection and RGB connections (if this matters).
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You will need a seperate Freeview decoder for the recorder. I don't believe there are any dvd recorders with built in Freeview decoders.
    Google is your Friend
