Results 1 to 23 of 23
  1. Member Tbag's Avatar
    Mar 2006
    What is the best registry cleaner to get to fix prolems and is easy to use?
    I used to use Norton Systemworks one button checkup alot until it stopped working one day and I found out how much memory Norton takes so I havent used anything since.
    any reccomendations?
  2. Regseeker works rather well & is freeware
  3. Member ahhaa's Avatar
    Feb 2005
    Michigan USA
    This came up recently in another thread...
    A couple of the 'free' Reg cleaners try to scare you into upgrading to a paid version.
    Some that were recommended were Abexo, Eusing, and Crap Cleaner (really!:]); Google or search here for that back thread.
  4. Member daamon's Avatar
    Melbourne, Oz
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  5. Member Soopafresh's Avatar
    Jan 2004
    Download and use Rdilly BEFORE you run any registry cleaner. 1 Click reg backup and restore.
    http://www.joejoesoft.com/vcms/124/
  6. Member daamon's Avatar
    Melbourne, Oz
    A good point - back up your registry before cleaning it!!!
    Registry Mechanic offers that option before each use. Naturally, it also has a restore function too. Look for this in any others you try out or end up choosing.
    Carpe diem.
  7. I think ccleaner got the registry cleaning option
  8. RegSeeker also allows backup function. Compared it to CC & RegMech, & it seems to find more junk to fix...All are good apps.
    Apr 2003
    Maryland
    RegSupreme Pro consistently finds more errors and invalid entries than anything else I've ever used. Also backs up before repair /clean is performed after the initial scan.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  10. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    It doesn't matter which registry cleaner you are taking about, the more aggressive the settings, the more likely the software will clean away something it shouldn't. To be foolproof and precise, you really need to study the registry intimately.
    Feb 2004
    Australia
    slacker ... true ... but that's why you need a backup in the first place ... if the end result is a screw up , you can atleast return the system back to previous state ... and try again ... there is no need to study the registry ... simple seach with google using key value will help most understand what a registery item and event dose ... from here ... they can make a valid choice as to keep or remove the item .
    Run regedit ... locate folder item containing key / value ... copy key name ... and google search it will show result's ... it's then a little digging as not all result's are acurate ... some people have no idea what they are talking about online these day's ...
  12. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    I'm happy with jv16 Power Tools.
  13. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I use an older version of Registry Mechanic. CCleaner is also very handy to have in your arsenal as well.
  14. Member Tbag's Avatar
    Mar 2006
    I got Registry Mechanic but im afraid of clicking the repair button.
    I took a screenshot of the results can anyone that has this let me know what not to tamper with.
    I didnt know how to post a direct image so heres a link of the results of the scan
    http://img53.imageshack.us/img53/6005/screenhunter002no5.jpg
  15. Member daamon's Avatar
    Melbourne, Oz
    There should be a way of seeing exactly what the entries are for each category that are identified as needing fixing. Find out how to view those, then...
    Review:
    Custom Controls (2) - Not sure what they are. Take a look and post details if need be
    Shared DLL's (2) - Probably left over from uninstalling software
    Deep Scan (154) - Probably mostly moved or deleted files
    Fix:
    Add/Remove Programs (25) - Programs that have probably been deleted
    Temp Files/Shortcuts (423) - Exactly that. Junk - get rid of it
    File Extensions (1) - Exactly that. Probably unassigned / no longer required
    https://forum.videohelp.com/viewtopic.php?t=271697
    Carpe diem.
  16. Member Tbag's Avatar
    Mar 2006
    it does show what the entries are but it means nothing to me, will it be unsafe to just repair the lot
  17. Member daamon's Avatar
    Melbourne, Oz
    Without reading through all 700ish entries, the only way is to back up the registry, repair and see how it goes.
    If you're really worried, have the right software and a spare hard-drive - back up the entire drive with the Operating System on (invariably the C: drive).
    Carpe diem.
  18. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    It creates a snapshot of the registry before it repairs anyway.
  19. I found Registry Mechanic too envasive for me. It kept deleting some passwords and changing settings. I got rid of Norton a long time ago. I just discovered Wise Registry Cleaner and it works for me. Its free with no nags so far. No guarantees however since I just started using it. www.wisecleaner.com
    Bert
    PIV-2.4G ASUS MB, 1G Mem, WinXP
  20. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    I've had a nasty intermittant startup problem, which I suspected was the results of a failed install of Norton Save/Restore. Uninstalled the partial restore at the failure and deleted files.
    Downloaded regseeker used its registry search feature and found 22 reg entries associated with Norton Save/Restore. Deleted them with regseeker and so far the problem has not occurred. Other reg cleaners never noted the entries which referred to non-existant files.
  21. Member Tbag's Avatar
    Mar 2006
    thanks for all your input, I might just hit repair all knowing that I can undo it if something goes wrong
  22. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    The registry cleaner apps usually won't screw up anything. It's normally quite safe to let them do their thing. And like you said, you always have system restore if you need it
    On the other hand, you can do some real damage with an app like Hijack This! if you aren't positive about what you're removing But again, with system restore all you've lost is 5 minutes if things don't work.
  23. Originally Posted by Alex_ander
    JvPowertools is for me too. It works great. I've never had the need for anything else.
    Darryl
