    Jan 2007
    HELP! My viewfinder and monitor is completely filled with vertical colored lines, I can not see any images what so ever? Last time I used the camera it worked fine. Has anyone had this problem before, can I repair it myself? Any feedback is appreciated.
    Cheers
    KL
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    About all you can try yourself is replacing the batteries. There isn't much on current cameras that is user adjustable/fixable. You will need to put it into the shop.
    Google is your Friend
    Jan 2007
    Is this a common problem that occurs?
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    No, I'd just say it is failing or has failed. Could be the result of being dropped or mishandled, or it could just be faulty electronics.
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Are you watching live picture or from playback?
