Newbie here- I had a power outage and after that I get error reading" Media Center Receiver Service has encountered a problem and has to close : the error info reads : szAppName:ehrecvr.exe szAppVer: 5.1.2715.2812 AND szModName CinemasterAudio.DLL szModVer:2.8.6.1418 offset 0000c76"
Can anyone help with this. My Media Center will not work now and says the " tuner is not available" thanks
eightiron / jan 07/07![]()
Sounds like this is running on a pc (HTPC)? You can try reinstalling the software or performing a restore back to a date when it was working. Sounds like some files were corrupted.
If it is a standalone piece of hardware, you could try resetting it or taking it in for service.Google is your Friend -
thanks much- I did that three times before it worked- why I don't know- It's running on Dell 9150 which came with the installed Media Center so I could not isolate the tuner. When I spoke to the Dell people- three of them- they all had a diff. idea- - your's worked. Thanks again. sirzack
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 22:39 -
Sony DVCAM and AV/C tuner driver problem
By Sean_ve99 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Nov 2009, 18:34 -
ASSUS TV TUNER interlaced problem
By Docoptik in forum Capturing and VCRReplies: 15Last Post: 15th Aug 2009, 08:11 -
Tv Tuner (deinterlace) Problem
By harry29 in forum ComputerReplies: 1Last Post: 5th Mar 2009, 12:17 -
Problem with Hauppauge USB 2 Tv Tuner
By JustinR123 in forum Capturing and VCRReplies: 4Last Post: 29th Jun 2007, 03:01
