I plan on getting this card with my new PC build, however the OTA towers are to far from me to go with anything smaller than a 'large roof antenna' (30+ miles with CBS at 60.1 miles), so it looks like I will have to hook up a Cable Box (either the SA8000HD or SA8300HD) to the card. Cable CO is Brighthouse/Tampa FL.
I'd like to capture the TS files to my PC, and have read that the Firewire ports on these boxes don't work right (CapVHS crashes, etc). I will have a HDCP Video Card and Monitor, so is there any other way to get the non-encrypted (any?) HDTV TS files to my PC with this setup, or is it pretty much useless?
	Cable companies are required to carry unencrypted the digital channels that can be received OTA in your area. So with a tunner card capable of QAM decoding and digital cable subscription you will be able to decode those channels on your PC.
	I live in Hartville,OH and have Time Warner's 8300HD. I recently purchased the same Fusion card as you have.Originally Posted by mz_
 As you know, the Fusion card uses software drivers. So you must make a decision on installation to receive OTA ATSC video or cable QAM video. I have played with both versions. Uninstalling and reinstalling the drivers.
 I took the cable that feeds my TW box and split it, feeding both PC and 8300HD. In the cable QAM mode on the Fusion drivers, I am able to recieve all the local HD channels (from the 4 major networks) plus the analog channels 2-79 SD content.
 Using the Fusion software I can record all of the selections.
 I hope this helps?
  Need help to use IEEE with 8300HDBy GhostMan55 in forum DVB / IPTVReplies: 3Last Post: 29th Jul 2010, 21:48
  Good DVD Recorder for 16x9 HD copies from SA 8300HDBy rba46 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 31st Mar 2010, 16:07
  Hdmi Difference Between Silver & Gold?By ofield1 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Mar 2008, 17:07
  SA 8300HD Firewire CaptureBy nebbish_2112 in forum DVB / IPTVReplies: 0Last Post: 30th Nov 2007, 09:15
  Questions about Dvico FusionHDTV5-RT GoldBy Lascivious1 in forum DVB / IPTVReplies: 10Last Post: 9th Jul 2007, 10:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
