    Sep 2006
    hi all:
    i hope to purchase an external harddrive for my powerbook g4. i capture clips to show in class and would like to save them on a harddrive and freeup the space on my mac.
    any recommendation?
    thanks in advance.
    three_m
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Anything Western Digital gets my nod of approval.
    Western Digital Drive
    Others on this forum like Seagate, AcomData, or Lacie.
    One thing I would mention, if you can afford it get
    a Combo Ext. Drive, that has both USB2 and FW connectivity,
    as it is much simpler if you have a video file on the drive that
    you need to share with a PC using teacher/administrator
    to do so with a Combo connectivity drive.
    But if you ABOSLUTELY know you will always be using a Mac,
    then stay with a FW connectivity drive.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Sep 2006
    thanks.
    i have a pc in my office, so a combo external drive is the one i should get.
    three_m
    Jan 2007
    As someone who uses many drives in demanding multi-track audio my first choice is Seagate Baracudas or Western Digital. At least 7200 rpm. You can always fine deals on these at Circuit City and Best Buy. Sometimes in the store they have deals that are not listed in the paper. Then find a good FW and Or USB housing to put them in (easy to do - 2 plugs and the right jumper setting, usually Master.)
  5. Got a 500GB Western Digital MyBook Premium. Very nice enclosure, quiet. With USB2 and Firewire connection. So far, i am really satisfied.
