I tried to use Ulead to capture analog source at 640x480 to AVi format. I see jagged edges for moving objects when I pause to look at a frame. It seems like the frame captures 2 interlaced shots and moving objects gets a ghost. One gets capture by the even scan lines, the other by the odd lines.
Is that right?
How do I fix it? When I use MPEG and turn on deinterlacing, the problem seems to go away. But I really would like to capture to AVI.
Thanks.
Yes yours is the typical interlacing problem and is very common for videos captured for a higher vertical resolution( > 240). You could capture to AVI and apply a deinterlace filter using Virtualdub http://www.virtualdub.org . This deinterlacing filter only sort of blends the interlaced areas and sometimes may not yield a good picture. You could alternatively use Avisynth http://www.videotools.net and try other methods described for deinterlacing.
Problem with motion getting jagged lines
By philflo in forum Video ConversionReplies: 2Last Post: 6th Mar 2012, 08:27 -
Jagged Edge Of Video Picture
By kenryuakuma in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2011, 07:24 -
Removing jagged interlacing artifacts from a progressive file?
By tfolder in forum RestorationReplies: 13Last Post: 17th Mar 2011, 04:19 -
Problem with Magix Movie Edit 14 - Sound muted between objects.
By Jo The Veteran in forum EditingReplies: 1Last Post: 3rd Jun 2009, 17:49 -
Need software for advanced editing (moving objects)
By eric0524 in forum EditingReplies: 13Last Post: 7th Jul 2007, 20:05
