Results 1 to 14 of 14
  1. I've seen a few mics be recommended. I use onboard sound from my motherboard. No actual soundcard. I'm not looking to really upgrade either. However, I'd like to do some voice over for a video. Will I notice a difference in voice quality with a more expensive mic? I use a cheap $10 mic right now and it's shit. Any suggestions?
    SmileSmile
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    I have used the cheaper microphones and a few that have cost over $100.00 bucks, You can tell the difference, but for doing voice overs you should have no problems. Just make sure to set the volume for the mic up. You can always use an audio editor to enhance the audio recording before you use it in the Video. Good Luck
  3. Any recommendations on which mics are good?
    SmileSmile
  4. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    If I needed a Mic, I'd get the Snowball by Blue. It's a way cool USB Mic.
    http://www.bluemic.com/modules.php?op=modload&name=Products&file=index&prod_id=18
  5. Does that work? Will it do the job? Or is it just for show?
    SmileSmile
  6. Member Epicurus8a's Avatar
    Blue makes professional quality mics. The Snowball is their first pro-sumer product. If you look around, you should be able to find one for $100 or so. Shipping to Japan would be extra...
  7. I wonder if they have this in Japan so that I can avoid the shipping.
    SmileSmile
  8. Aging Slowly Bodyslide's Avatar
    Feb 2002
    From the Maker:
    Japan
    Digidesign Japan
    Yasuhiko Yoshida
    JAPAN
    Phone: 813-3505-4028
    http://www.digidesign.com/bluejapan
  9. Member Epicurus8a's Avatar
    Bodyslide is right, though. You could spend less money, but it probably wouldn't be as cool looking. Look on auction sites for better prices.
  10. Originally Posted by Bodyslide
    From the Maker:
    Japan
    Digidesign Japan
    Yasuhiko Yoshida
    JAPAN
    Sweeeeeeet
    SmileSmile
  11. Damn...the mic is almost 350 dollars in Japan
    SmileSmile
  12. Banned
    Dec 2005
    Canada
    ... but think how much you would save on shipping!
  13. Aging Slowly Bodyslide's Avatar
    Feb 2002
    Stick with the one you have then edit the recording with Audacity...Good Luck
  14. Originally Posted by InXess
    If the mic is 100USD in America, shipping would have to be less than 250USD to be worth buying. I doubt shipping would be more than 20 or 30USD.
    I will try. Thanks.
    SmileSmile
