Is there such a portable dvd that uses a power cord instead of batteries? cause I want to watch movies for like 6hours instead of 2-3 hours. If know any shops in Australia sell them please recommend me
It's a power supply that runs the player off the mains instead of using the batteries. Many portable players have these as an option, though you may have to purchase it separately if it's not included with the player.
Most portable players come with an adapter too recharge the battery ... and too play dvd's direct from adapter supply .
It would be lame to get a unit without this device ... it's deemed as an unsaleable item under au law and fair trading .
For in car , you need a proper adapter ... not a cheap and nasty one ... just because they say they can on the packaging dosent alway's guarantee they will , or how long they will last before curling up and dying on you .
In this case , you might be looking for an inverter , with "full sinewave rectification" ... esspecially if using a notebook / laptop in car ...
Half sinewave rectified units will eventually destroy the batteries in any portable device ... I hate missleading information from some site's that say they dont , but believe me ... they do and will kill the batteries sooner or later ... and some batteries are not cheap or easy to remove and replace ... yet alone "get a replacement" asap when needed .
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 17:28 -
Portable DVD Player Help
By eastpole in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2009, 11:39 -
Portable DVD Problem
By erebuss in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Feb 2008, 17:02 -
DVD to portable HD that still has CC for a TV Guardian
By drormsby in forum DVD RippingReplies: 4Last Post: 25th Nov 2007, 16:23 -
Portable DVD Help
By thedevster in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2007, 00:25
