Hi All,
I have a video in DVType2 format from my Vcr/Camcorder->Firewire, that according to GSpot, is Interlaced and TopField First. When I import this video into Sony Vegas 7.0, what field order should I use for DVD play back for computer, and dvd players for TV, Progressive or Upperfield?
I read some where if your video is interlaced it needs to be kept as interlaced using progressive. When I tried this I noticed the frames weren't lined up correctly in Dvd Lab Pro unless I use TopFieldFirst, with blendings set on deinterlacing on the video.
I'd appreciated if a vegas user could tell me what my projects settings should be set to, for this type of video for dvd play back.
Thanks.
Matt
[***Assuming you're going to end up watching on a std TV***]
If your source is Interlaced, don't do ANY deinterlacing. Encode/Compress it leaving it as interlaced. IIRC, DV is ALWAYS TopFieldFirst, so it should be left that way also.
Scott -
Field order selection depends on the device it was captured with or recorded on, you want to maintain whatever it is.
BFF for DV: https://forum.videohelp.com/viewtopic.php?t=257631&highlight= -
Sorry (BFF, I should have known!), it's been a long week!
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 07:58 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 06:06 -
Swapping field order in progressive video.
By jmail524 in forum Video ConversionReplies: 1Last Post: 3rd Aug 2008, 12:53 -
Interlaced XViD playback on Standalone - Field Order Problem
By nbarzgar in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 07:04
