    Jan 2007
    Portugal
    hey!!! im a Mohaa demomaker and when i try to capture in uncompressed the progam (iuvcr) only record 4 mins then he stops recording...i also try with other progams and its the same thing... but with other codec like morgan Huffyuv PicVideo etc it works :S...
    Apr 2005
    Rio Grande - Porto Alegre - RS - Brasil
    Capturing uncompressed needs A LOT of hard disk space and, in my opinion, it's not worth.
    Are you using FAT32 or NTFS on your drive? If you use FAT32 it may be reaching the limit (4gb per file) very fast, as uncompressed makes HUGE files.
    Jan 2007
    Portugal
    im using FAT32... do i need to change? if i do how???
    Jan 2007
    Portugal
    heyy dont worry my bro already helped me :P ty m8 @@@@
