I'm receiving this error message, when I try to burn to multiple recorders at once. Is there anyway to get around this problem.
No common write speed for these recorders.
Do you mean to a DVR or a computer DVD writer? What program are you using to burn with? I've done this with Nero and never had a problem. Are you burning the same file or two different files? And what is the exact text of the error?
A little more info would be helpful.
And welcome to our forums.
I'm using Nero, and this is the message that it gives me. I am burning one image file.
No common write speed for these recorders. -
Are they using the same bus type?
Are they the same (or very similar) model?
Do you have "MAX" as the speed setting on both?
Find a Lowest Common Denominator...
(give us more info also)
Scott -
the LG drive will only let me burn at 4x and the HP drive will only burn these discs at 2.4x
disks - Memorex dvd+r dl 2.4x
hp dvd740e
lg gsa-h22n -
Could be your choice of those particular Memorex discs might be the problem...
Get better media, something that'll record at a faster speed (e.g. 4x, 8x). Then, you'll have something that both burners should be able to burn simultaneously.
(Once again, Memorex rears its ugly head!)
Multiple filter problem with ffmpeg - help please?
By Orinoco Womble in forum Video ConversionReplies: 6Last Post: 6th Sep 2011, 19:09 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
Batch hard encode multiple language srt to multiple videos
By clonius in forum SubtitleReplies: 4Last Post: 15th Jul 2010, 15:06 -
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 12:27 -
Unable to burn with multiple DVD recorders with Nero 7.9.6.0
By Burner127 in forum Authoring (DVD)Replies: 1Last Post: 7th Jun 2007, 00:47
