    Jan 2007
    Hello folks, I bought the great little Silvercrest KH 6510 which I found to be great, up until a few days ago the sound on my Divx files are gradually going out of sync throughout the episodes.
    They were working fine and now they are not, the stuff works on my other divx players so it is not the files it seams to be just on this player.
    Help please anyone, its very hard to watch a scary film when the sound gives away the scary bits before you see them.
    Chris
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    If the files/discs work fine in other players, then I expect you have some hardare issue/failure within the player. Aside from ensuring the files are using cbr and nor vbr audio, I don't know of anything that you can do to the player to "make" it work.
    Google is your Friend
