Hi, I have a Sony NS585P dvd player and I found out at the hacks page that I can hack it just by using an infrared device made by me. But I cant find the necessary items for that, so I thought that I have some other devices that have infrared. Those are my PSP and my Sony-Ericsson K750i mobile. For both there are programms that control other infrared devices. This is the programm for the psp: http://www.psp-hacks.com/file/287 . Can someone tell me the codes that I need to hack my dvd player? These are the normal codes for my dvd that I found: http://www.remotecentral.com/cgi-bin/codes/sony/dvd-s57000/ . Thanks
Do a google search on your player and hacks. You should come across the procedure.
Google is your Friend -
I couldnt find anything... By installing this homebrew on my PSP I can control any device with infrared if I have its hex codes. I have found the hex codes of my dvd player in the above url and I tested them and it worked just fine. I just need someone to tell me the hacked hex codes in order to replace the original ones with them. After doing that I will be able to hack my dvd player without having to buy another remote. So, can anyone tell me the hacked hex codes for buttons 1-5?
Is there a way to hack a Chrysler DVD player?
By Kiannshysmom in forum DVD & Blu-ray PlayersReplies: 9Last Post: 18th May 2010, 23:13 -
DVD Player Hack
By jgibson in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2010, 20:48 -
Encoding iPod/mobile + PSP AVC compatible files.
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 11th Sep 2009, 03:42 -
PSP and Flash Player
By snafubaby in forum Portable VideoReplies: 0Last Post: 22nd Feb 2008, 20:29 -
Hack Code for SilverCrest Mobile DVD Player KH 6500
By harassedmum in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Dec 2007, 10:07
