I upgraded my PC about 2 weeks ago. The new graphics card has DVI and TV out, two features I hadn't had on the previous card.
Recently I started playing Doom 3. When it first came out several years ago, we didn't have a PC with enough "huevos" to run it, like many people complained about. iD Software even admitted their gaffe making it so large and resource-hungry.
With the new upgrade I can finally run it flawlessly 8) The game has some amazing graphics
Yesterday I played around with the TV Out feature on my card and plumbed it into my Snazzi MPEG capture box on the other PC, hoping to grab some video to play with.
All it shows is a static image of my Windows desktop, with no desktop icons or video content. Even after I start Doom 3, the scene is the same. I suspect it's because Doom 3 is a pseudo-DOS game still, and the card's driver won't support this mode. When, oh when will games be purely 32-bit or 64-bit, and get away from the legacy 16-bit programming entirely?![]()
I know we have lots of video-knowledgeable people here as well as many gamers, and many computer and video-savvy gamers. Any ideas? Thoughts? Has anyone encountered this problem and found a workaround for it?
Instead of extending your desktop onto a second display, put the second display in mirror mode (ie a copy of the desktop). And for movies enable Theater mode in the ATI drivers.
Thanks. I tried that and it looked horrible.
I think I have a workaround:
1. Created autoexec.cfg in doom3/base dir:
That sets up F10 to toggle demo recording mode.set startrec "recordDemo; set demorec vstr stoprec"
set stoprec "stopRecording; set demorec vstr startrec"
set demorec "vstr startrec"
bind F10 vstr demorec
2. Recorded demo (file ended up as base/demos/demo000.demo).
3. Set Doom 3 to run non-full screen in Doom setup options.
4. Started Camstudio to grab video off desktop.
5. Started Doom 3 and using console, entered "playDemo demo000"
Camstudio grabbed it as an AVI. Perfect! 8)
Using Camstudio on the actual game running in a window caused the mouse cursor to show on the screen. This goes away when running it full-screen. I use the mouse for aiming, firing and turning, and a gamepad for gross movements. -
Originally Posted by jagaboOf course it looked horrible. That's what happens when you downsize a hires display for NTSC video.Originally Posted by Capmaster
Understood. But it looked worse than just NTSC on a hi-res display (it's only a $39 card).Originally Posted by jagabo
The AVI capture option seems to do the trick. It's a lot of work, but the results at least give me something I can work with.
Thanks for your help
Maybe that card has bad tv out or you needed to make some other adjustments? I have an X300SE in one of my computers and it looks about the same as all my other computers' TV out -- similar to DVD player.
In any case, the direct screen capture you're doing now will work much better. -
That's the way I'm leaning. I don't plan to spend a lot of time recording Doom 3 videos, so the few extra steps required for using Camstudio is fine. The results look very nice 8)Originally Posted by jagabo
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40
