hi all
i recently got a laptop which came with NTI CD & DVD Maker 7 Gold... i tried it out and was pretty dissappointed... it seemed to burn the cd okay, but while i was dragging files to be burnt it would occasianally freeze up for a few seconds...? any ideas why that could be.... havent had any problems at all with anything else...
i have always used NERO... which i think is the best...
i do have a copy of NERO which came with my burner in my desktop... would i be able to get that working on my laptop? i think it is an OEM version tho..
Usually, any OEM versions of Nero that come bundled with a burner, only work with that burner. You could still try it. If it doesn't work you are only out a few minutes of installation and removal time.
Google is your Friend -
Later OEM Neros work with any burner (6.x). Nero 5 had more restrictions.
okay cool... i will give it a go...
is it okay to have to different burning softwares installed at the same time? should i uninstall the other first? -
Older versions someimtes conflicted with each. It seems to vary from user to user. They should work without any problem, but the only way to know is to try.
Minor(?) problem with Intensity Pro analog output
By Dandy J in forum Capturing and VCRReplies: 1Last Post: 18th Apr 2011, 21:58 -
Minor Problems with DVDClone
By jbd441 in forum DVD RippingReplies: 2Last Post: 19th May 2010, 15:25 -
Software Problem NTI Media maker no menus
By music_freak in forum Authoring (DVD)Replies: 3Last Post: 19th May 2009, 17:32 -
A minor problem using CovertXtoDVD ( double layer dvd+r needed)
By nadizo in forum Newbie / General discussionsReplies: 11Last Post: 18th Mar 2008, 16:13 -
Really Minor Issue
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 13th Oct 2007, 14:47
