What's the differences between these 2 and what's better for encoding
Basically HE uses SBR and LC doesn't. Which is better depends on the bitrate. Most encoders will disable SBR above a certain bitrate automatically anyway. Also depends on what you mean by "better". LC is certainly more supported in terms of playback.
ok thanks for the reply. i'll stick to AAC-LC for encoding as it's more common. i've got an issue with megui for encoding from an AC3 file to Nero Digital AAC stereo. The volume is low even if i choose the option to increase volume automatically. Is there a way to increase it more?
Hi,
I have also found that "Increase volume Automatically" doesn't do much, Although MeGUI is a great program I use dbPowerAmp and it's mp4 plug-in (which is FAAC) for audio conversions, the "normalize" in dbPowerAmp works very well. -
could you tell me how to use it and where can i download that mp4 plugin and FAAC
http://www.dbpoweramp.com/dmc.htm is where you get dbPowerAmp, don't let the trial version scare you if you use it for AAC encoding then you don't have to buy it, the .mp4 plug-in is at the same site in the "Codec Central" section. As to the post above regarding FAAC I use FAAC and Nero about 50/50 maybe I'm gettin' old but I don't hear any difference in output quality, there were some buggy FAAC builds but this one is rock solid!!
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 09:41 -
mux h264/aac flv into h264/aac mkv
By Pitorasilo in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2011, 10:36 -
AAC 5.1 to AAC 2ch conversion problem
By MR 3 in forum AudioReplies: 6Last Post: 2nd Feb 2010, 23:44 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 17:58 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:41
