can anyone tell me why video redo makes a new mpeg which is out of sequence after i have made a few cuts from the original file
thanks
What's the source file ?
If it's a tv recording, were there any glitches in the original - because this can cause sync issues ?
Also, when it finished and shows the results/stats, were there any frames removed/resynced etc. ? (was there any red ? lol )
If there are glitches in the original, then it's probably a good idea to run a 'quick stream fix' from under the 'tools' tab.
Another question, was the out-of-sync issue the same the whole way through or does it vary at different parts of the video ? -
all the cuts i made were taken out perfectly,its just that the finished mpeg was out of sequence,so the last part comes first and so on.
i have used different mpegs from different sources but the result is always the same -
I use VideoRedo Plus and am new to this and have had no problems with it at all.
I load the video, select the cuts and just hit SAVE-AS button and never had a problem with any video
If the problem is not in the source video I suggest that your version of VideoRedo needs fixing. -
Originally Posted by spanky123
I think it's the actual Mpeg cut order.
Sorry, I have no clues as to that.The Devil`s always.....in the Details!
