Hi,
my problem,
Sony Vegas 7.0 MPEG Layer-3 Audio not Sync..
Setup it codec patch,
K-Lite Codec.
my Video convert to FourCC Code Changer...
Images:
big thanks!...
If I understand, you are converting from Xvid to DVD? You want to check for MP3 VBR audio. Gspot 2.60 will tell you. Look for the green 'VBR' window in the audio section. VBR audio can cause a lot of sync problems.
If you find it, you can extract the audio to WAV format with a program like Virtual Dub Mod, then either convert it to MP3 CBR, or AC3 audio if you are making a DVD. A guide here: https://forum.videohelp.com/viewtopic.php?t=280779
The K-lite codec pack is usually not a good idea. It can damage your existing codecs and cause other problems.
And welcome to our forums.
oh. Many thanks your attention,
am not change XviD to DVD,
i need only make to Scarface Music video.
then render to .wmv or rm ..
my Vegas why open a DivX audio formats
***i dont like converting and etc..***
first time setup vegas is running, (XviD) audio sync not problem and view error
delete my codecs, re setup other K Lite patch old version and audio error
This time, change to Scarface XViD to DivX with FourCC software.
add a vegas and not audio sycn
Ohh! new problem.. VirtualDubMod give to .wav audio stream.
and add a vegas not open it
My Vegas software problem .. = MPEG Layer-3 audio not support
why please help..
Vegas hates VBR MP3. Use virtualdubmod to replace the VBR MP3 audio track with an uncompressed wav version, then open it in Vegas.
Read my blog here.
oh!... thanks. my problem resolved.
answer =
Sony Sound Forge Plug-ins copy to Vegas
open files format....
Thank you so much.
Problem with importing audio from movie track - Sony Vegas Pro
By tooninoz in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2010, 01:39 -
Sony Vegas Pro 8.0 : Problem to encode audio file into mp3.
By flash_49 in forum Video ConversionReplies: 0Last Post: 20th Jul 2010, 07:21 -
Sony Vegas 9 Audio Problem
By fdegrano in forum EditingReplies: 4Last Post: 24th Jan 2010, 20:13 -
Sony Vegas Studio 9.0b out-of-sync video/audio on VOB files
By javaguy in forum EditingReplies: 2Last Post: 24th Mar 2009, 13:26 -
Sony Vegas audio stream problem
By PoT in forum Newbie / General discussionsReplies: 11Last Post: 10th Aug 2007, 14:35
