i have a video file i recently came upon and it has xvid codecs and ac3 audio format tried to convert with tmpegenc and it puts out a wav audio file instead of ac3 which is what i want my question is how can i disable the audio conversion and extract the audio from the file and just convert the video. sry if this is confusing but its been a long day and im tired. thnx for the help in advance
Youcan use tmpgenc to demux the audio and video. This will give you two files. Then you can do as you please. The audio can be either wav or ac3 depending upon the settings in tmpgenc as KK said.my question is how can i disable the audio conversion and extract the audio from the file and just convert the video.
I assume you have an avi with ac3, demux the ac3 with virtualdubmod, streams->stream list->select ac3 track and click demux.
Encode the video as usually.
Add the video and the new ac3 when you author to dvd using for example TDA. Or multiplex the ac3 to the new mpg video with tmpgenc, file->mpeg tools. -
@baldrick, in the years since your Guide https://forum.videohelp.com/viewtopic.php?t=186739
... have you found any better method than BeSliced to "fix" the extracted ac3 file if it isn't being accepted by TDAuthor?
I've been having a few sync issues with "fixed" ac3 files lately.
How do you extract ac3 from m2ts when tsmuxer doesn't read the audio?
By yoda313 in forum AudioReplies: 6Last Post: 1st Jan 2011, 09:28 -
HELP for extract DTS or AC3 audio from MKV
By Riversound in forum AudioReplies: 5Last Post: 29th Jan 2010, 11:56 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 18:42 -
extract entire ac3/dts audio track from a DVD
By shiet in forum AudioReplies: 1Last Post: 24th Feb 2008, 03:26 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 05:56
