Results 1 to 16 of 16
    Jan 2007
    Canada
    I have exported the video I edited and created with vegas studio into wmv file format.
    But when I upload the video to youtube. after playing and lisstening/watching it.
    I notice that some of the sounds in the video becomes silent?
    it's not that all the sound goes silent when it happens.
    it like two sounds in the video out of all the sounds in the video..become silent...
    the weird thing is...one of the sounds is in the same audio file...
    meaning the beat plays...but the layed trumpet sound on the beat becomes silent?
    it is a big part of the video...but you cant hear it...cause it's silent...
    I realized later...that when it plays on wmv it sounds perfect and
    what I want it to be...with no silence at all...
    but when it plays in flash...what youtube uses....some of the sounds become silent?
    I am so lossed...I uploaded to youtube with three dif file formats three times...
    but after every upload...everytime I view the video...parts of the sounds are silent???
    I even checked on different computers just to make shure...
    if someone could please help me. would be great.
    thanx.
    Jun 2004
    Victoria, Australia
    I'd make a guess that YouTube are re-encoding the audio track to a lower bitrate, and this is causing some high-frequency notes (the trumpets) to get dropped in the compression.
    Trev
    Jan 2007
    Canada
    thanx man.
    is there anything I could do to stop the high noise dropping?
    what audio formats have you tried? what audio settings? stereo? 48hz? bitrate? I have used mp3 without any problems.
    Feb 2006
    thanx.
    Windows media video is restrictive like that its really not the best quality at low bitrates streaming music videos are at like 312kbps bitrate but you definatly get pixel dithering in wmv format, as far as the audio cutting out in a youtube video ive had the same thing happen to me but it was a swf video, shockwave flash format i tried uploading it to youtube b/c i know i can convert flash videos but the audio was cutting out, and the same thing as that was happening when i would convert some wmv videos to ipod format so i would have to burn it as a VCD first then get the DAT file off the VCD and convert that and its all good after that. Gooda did you try mpeg 1 video? thats used on VCD discs and the music videos and some other videos on file sharing networks but my digital video camera uses windows media (ASF) format for the videos but they convert just fine
    Jan 2007
    Canada
    this is the specs of the video I'm trying to upload.
    when I covert the wmv to mpeg1 and play it. parts of the video play faster then
    what I want the video to play...causing some of the audio to be off??
    I tried the video bit rate you said...312..
    and the auto bitrate 1600. same outcome both mpeg1 videos
    Jan 2007
    Canada
    ahh...I'm lossed. dont know what to do to fix the problem.
    if you could help. would be great. thanx.
    Jan 2007
    Canada
    dont know what to do....???
    Jan 2007
    Canada
    help please?
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    You have to convert to something else than wmv/wma. You should able to export to several video formats using vegas. mpg, mpg2, avi/divx/xvid with different audio formats.
    Jan 2007
    Canada
    thanx for the help
    yeah I have got a divx of the video to run smooth on youtube.
    but that audio problem still exists...?
    sample rate is 44100hz
    what should I do to fix the audio problem?
    Jan 2007
    Canada
    I have tested the sound that dosn't play on youtube on a video to flash program.
    I turned the divx video into a flash video with mono audio...but when I play video with 44100hz mono audio. the trumpet sound sounds real low...compared to the other sounds
    that play at the perfect volume?
    how can I fix this mono sound problem?
    youtube only supports mono..and without that sound playing
    at the right volume in the video...my video playing perfect on youtube is gonzo...
    if you could help me out. would be great. thanx.
    Jan 2007
    Canada
    need help real bad. cant fix problem ?
  14. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Most likely the problem isn't in your source material, but in the way YouTube is conveting the uploaded files. Have you tried contacting YouTube?
    As an afterthougt, ensure you aren't using VBR audio.
    Google is your Friend
    Feb 2006
    youtube reccomends Divx video, mp3 audio use 22,050 hz mono 320X240 dementions try those and get back to me im sorry i havent been on here that much i was just browsing around the web
  16. To me it sounds like you have a stereo source, Youtube is mono.
    Therfor if your right and left channels are inverted when they are mixed together anything that is in both channels is cancelled.
    You can see the effect in VLC under the audio tab.
    I suggest you convert your audio to mono and make sure it sounds proper and upload as mono not stereo and see how that works.
    Good Luck
