I have a couple of DivX movies of size 700MB-ish which play fine both on local hard disk and over a LAN connection. However when I burned it onto a CD - using ISO format - the playback becomes rather bumpy. The file is of format 640x304, 23 frames/sec, 24-bit, DivX Codec, 105kbps. The length is 1 hr 51 mins = 111 mins. If a 74 min audio CD plays fine on 1x player then my 24x CD-ROM should be able to handle that amount of data rate easily, right? Or have I missed a step when making the CD?
Burnt Blu-ray not playing on PS3
By cyberpimp16 in forum Blu-ray RippingReplies: 1Last Post: 14th May 2009, 12:53 -
Burnt DVD with vob problem (not playing on computer)
By lamaddvd in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2009, 15:28 -
playing burnt dvd's
By deadgirl in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2008, 00:56 -
Burnt several AVI's in Vista but won't play on Divx player... help
By mdavenport in forum DVD RippingReplies: 3Last Post: 29th Aug 2007, 14:51 -
'TMPGEnc DVD Author 3 with DivX Authoring' creates burnt-in subtitles?!
By abeelandig in forum SubtitleReplies: 4Last Post: 26th Jun 2007, 13:51
