I heard that deinterlacing video may cause quality loss. And I was just wondering if I were to render a project in Vegas, if I wanted to save resolution quality, that I don't use a deinterlace method.
If you plan on keeping the same resolution then I'd keep the video interlaced unless you plan on doing temporal (i.e., over time) based noise filtering to clean up the video before encoding. Even then, I'd personally (re)interlace after filtering and then encode.
By the way, deinterlacing video (i.e., converting frames to fields) will not cause quality or resolution loss as long as you keep both fields and either encode using the proper settings or (re)interlace before encoding.
Deinterlacing Question
By treed68 in forum EditingReplies: 4Last Post: 9th Oct 2010, 23:25 -
Quick question on Deinterlacing 30P in 60i containers
By ayim in forum Video ConversionReplies: 5Last Post: 30th Dec 2009, 21:06 -
Hello everyone! Got a question regarding Sony Vegas, Bob deinterlacing...
By mobious in forum Video ConversionReplies: 17Last Post: 12th Sep 2009, 12:48 -
Deinterlacing question
By Newbie 332 in forum Video ConversionReplies: 3Last Post: 15th Oct 2007, 20:50 -
How to use the deinterlacing in the TV when using the TV out from the PC?
By erik1958 in forum Software PlayingReplies: 2Last Post: 9th Jul 2007, 14:07
