I've got my current HTPC in an Antec SOHO server case that takes up way too much space...
I want to put it all in a 'desktop' style HTPC case, but I'm not finding many that fit my needs!
I need one that will house a full size ATX mobo and a full size ATX power supply.
Additionally, I need 3 front accessable 5.25" bays -- this is the hard part. I've got a DVD rom, a burner, and my sound card has a front control panel that uses a 5.25" bay.
I suppose I could get rid of my old burner (but there's nothing wrong with it!!! other than the fact that it's only SL and 4X) and lose the DVD-rom, but I would still need at least 2 5.25" bays.....
I've been eye-balling this Thermaltake case: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=371278 & http://www.thermaltakeusa.com/product/Chassis/desktop/mozart/vc4000sns.asp
but, it doesn't meet my final qualificiation -- it's not black....![]()
gawd I hate silver electronics.
Can anybody help point me to some decent HTPC cases that aren't more than 17" wide, ATX sized, are black, and have at least 2 or 3 5.25 bays on them?
I've also checked NewEgg and TigerDirect, but I don't know of any other reliable/reputable online PC gear vendors. CompUSA sucks, BTW.
Alternatively, how much of a pain in the ass would it be to paint that Thermaltake black, and how horrid would it look when it was done??
TIA!
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
There are lots of options with two or one 5.25" external bays for desktop form factor. I don't think I've ever seen anything like that with more than two. Your only option for that would be to get a regular ATX mid-tower and tip it on its side.
As for desktops there are some really attractive ones aimed at the HTPC market.
Here are two from Antec:
http://www.newegg.com/Product/Product.asp?Item=N82E16811129131
http://www.newegg.com/Product/Product.asp?Item=N82E16811129014
And then there are these awesome ones from Lian Li in black aluminum:
http://www.newegg.com/Product/Product.asp?Item=N82E16811112126
http://www.newegg.com/Product/Product.asp?Item=N82E16811112082
My friend has that last one and it's a fantastic case but I wouldn't recommend it if your home is really dusty.FB-DIMM are the real cause of global warming -
Try this website.... http://www.htpcnews.com/ they have a tonne of info on the site and the forum is very handy for questions.... i didnt see any reviews for the one you listed but I may have missed them.
good luck. -
http://www.pcalchemy.com/index.php?osCsid=fe08bc27ae0c6a61751ceb2ad8774eac
http://www.svc.com/htpc-cases.html
http://www.frozencpu.com/cat/l2/g1/c10/list/p1/Cases-Media_Center_Cases_HTPC.html
There's a few websites you can look at for HTPC cases. Good luck and let us know which HTPC case you decide on.
Which input for HTPC...VGA or HDMI?
By Moontrash in forum Media Center PC / MediaCentersReplies: 16Last Post: 1st Dec 2011, 16:06 -
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 12:09 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
One input record other input?
By Davron in forum Capturing and VCRReplies: 1Last Post: 30th Jan 2008, 17:20
