i'm totally new to this, i've got a couple of hundred vhs tapes that i collected in the 80's mostly 2nd or 3rd gen music stuff that i taped or traded, i'd like to get them on dvd, reading through the forums it seems the easiest method is to get a decent vhs deck and then record them on a dvd recorder?
so whats a good vhs deck? i'm in the uk and most the tapes are pal
is the panasonic svhs 950b any good?
if i got a dvd recorder with hardrive would i be able to put bits from different tapes onto the hardrive and then burn onto one disc?
i'm hoping to do this for around the £500 mark is this possible or am i dreaming?
and can anyone recommend a dvd recorder?
Same boat here. Try a JVC or Panasonic SVHS deck with tbc and dnr and a jvc dvd recorder with an lsi chip. I would recommend only xp mode and taiyo yuden or sony dvdrs (if they have those in england).
I have a Panasonic twin VHS and DVD Recorder / Player with which you dont have to do much more than put the VHS in one slot, press a dubbing button and it copies everything direcly from one to the other (or so the manual says, I havnt tried it). One later version (and more widely compatible than mine) is DMR-EZ45V but there are variety of others, readily available in the UK and I expect used earlier ones are on Ebay, etc.
clayto -
Originally Posted by deuce8pro
However, I would add another vote to the Sony DVDRs.
Originally Posted by ronbinthehood
As for being able to record, edit and put bits on one DVD: I have a Sony RDR-HX510 (a slightly older machine than is available now; no integrated freeview) and it allows me to do simple edits - usually trimming start and finish or removing adverts - and then dub over to a DVD. I understand that later machines may allow more sophisticated editing.
From a budget of £500, and knowing where to look, I think that would be quite reasonable as prices of DVD hard drive recorders are tumbling.
Good luck.Cole -
got a panasonic 860 off ebay, it has tbc and dnr, took me a couple of weeks as i kept getting outbid seems the decks with tbc are very popular at the moment, think i'm going to get the pioneer 440hx dvd recorder with 80g hardrive, anyone like to comment on this dvd recorder? will 80g be a big enough hardrive for my needs?
Finding sound engineers?
By takearushfan in forum Off topicReplies: 3Last Post: 27th Dec 2010, 20:04 -
A little help finding the right ripper for me, please?
By Cygnus111 in forum DVD RippingReplies: 4Last Post: 9th May 2010, 11:27 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
Help with finding dvd player for a non-HD tv
By missvanderhoven in forum DVD & Blu-ray PlayersReplies: 8Last Post: 19th Mar 2009, 13:35 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59
