    Sep 2004
    I am using Nerovision express 3 to rip DVD's to mpg's for DVD reauthoring. At times when i rip i get files that are the incorrect size to reauthor. I am using Encore to reauthor and it won't accept files unless they are 720x480. I get files hat are 704x480 and other sizes. What can i do to rip the file as 720x480? I'd rather not recode to get the proper size.
    Ken
    Switch to an authoring tool that supports all dvd-video sizes...
    You could use dvdpatcher to change the headers in video to 720x480 and then author and before you burn change back the vobs to 704x480.
    Sep 2004
    Can you recommend a program that allows more flexability when ripping?
    Ken
