I am using ffmpeg to extract frames of video to JPEG from a WMV file - passing in a set time to perform the image extract, etc. This all works fine, and the command is as follows...
ffmpeg -i C:\<vid_name>.wmv -ss 00:00:20 -t 00:00:1 -s 320x240 -r 1 -f mjpeg <image_name>.jpg
To build up a storyboard of images, I submit the same command over and over again - incrementing the "time to process" by 1 minute. This is very resource hungry since every time it has to load the file, scan through it and then take the image.
Does anyone know if it is possible to get ffmpeg to load the file once, and then take images at set intervals through the file - as this would be much more efficient.
My other question is if the above is possible, I notice in the command list comments regarding motion detection - could you do the same, but instead of specifying a fixed interval, simply trigger of motion..?
All help is appreciated!!
Results 1 to 1 of 1
2-pass in FFmpeg ?
By Klagar in forum Video ConversionReplies: 24Last Post: 5th Nov 2010, 00:40 -
ffmpeg 2-pass does nothing
By grv575 in forum Video ConversionReplies: 13Last Post: 6th Oct 2010, 20:24 -
Extracting frames from single PGM file
By lchen in forum MacReplies: 0Last Post: 18th Jun 2010, 04:49 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Finding and extracting single sound
By Nator in forum AudioReplies: 1Last Post: 25th Jun 2008, 03:27
