please help me out guys!!!
I am using winavi to convert files to dvd format...i want to burn 2-3 of these episodes to a disc but i can't figure out how to do it in nero...is there a better way??
when i add the 2nd file to nero it says the file already exists and i have to replace it....when i change the file names it asks for a certain filename which must be in all dvd files
what is the easiest way to do it??..
many thanks
You either have to encode them all at the same time in WinAVI (hint : try holding down the shift key when you load the avi files), or you should do what any sane person would. Uninstall WinAVI and try ConvertxtoDVD instead.
Read my blog here.
Multiple AVI is WINAVI being put on DVD in the wrong order
By richco in forum Authoring (DVD)Replies: 7Last Post: 23rd Nov 2009, 06:50 -
burning multiple mp4 files to DVD format
By dvdnewbie64 in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2009, 13:59 -
Any considerations when burning WinAvi converted dvd to a DVD+RW?
By AshleyQuick in forum Authoring (DVD)Replies: 2Last Post: 26th Jan 2009, 18:31 -
Burning 1000's of files to multiple dvd's
By lordhutt in forum ComputerReplies: 12Last Post: 14th Dec 2008, 15:45 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 13:01
