Hi Friends,
I tried searching my problem over the forum but can't find correct solution.
I have a lot of VCD Movies and I want to burn them again in my DVD to make a collection.
I want to know what is the best format and software to convert the VCD(.dat files) so that I can fit more and more VCD's in one DVD.I am not bothered about the DVD player compatibility as I can watch it on my PC.The thing I want is Quality.Please suggest a good converter and file type.
I am a novice to conversions so if you can give the details of settings or provide any kind of Guide my work would be easier.
Krishna Rocks
Extraction of mpg from VCD: VCDGear
Authoring of VCD mpg as DVD: TMPGEnc DVD Author
Compatibility will be 100% DVD specs.
Video quality will be exactly as the VCD.
Guides: See this site for the respective applications.
/Mats -
Guide for using VCDGear:
https://forum.videohelp.com/viewtopic.php?p=1153023#1153023If in doubt, Google it. -
Multiple (S)VCD to DVD with DVDLab
https://www.videohelp.com/forum/viewtopic.php?t=251691Cheers, Jim
My DVDLab Guides
adjust angles
By ecos in forum EditingReplies: 2Last Post: 31st Jan 2012, 17:00 -
Adjust audio level
By drgt in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2011, 13:03 -
How do I adjust the sound
By mmkk in forum Video ConversionReplies: 2Last Post: 28th Dec 2009, 13:52 -
adjust dvd subtitle position
By pcb in forum SubtitleReplies: 1Last Post: 27th Aug 2008, 18:42 -
adjust the volume
By volam in forum EditingReplies: 9Last Post: 1st Mar 2008, 19:19
