hello
I'm using ffmpegx 0.0.9 to convert avi to dvd ffmpeg
using the instructions on the ffmpegx site for avi to dvd
I burned the video.dvd folder using toast 7.
The dvd plays fine on the computer, but in the dvd player there is no audio when the charaters speak. I can hear background music in the movie but no talking.
Does anyone have any idea whats going on??
you can hear music but no vocals?
Usually it works only one way:
No audio means NO AUDIO at all.
Go back and Play the AVI with VLC.
Report back what VLC reports under the Information
setting on the streams in the file,
specifically Stream 0 and Stream 1, and what codecs
it sees are needed to playback the file."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
thanx for responding
yep, I can hear music and no vocals
stream 0
codecs : XVID
type : Video
stream 1
codec : a52
type: audio -
Does the music sound totally normal, or does it seem to be lacking in bass? And when you say "no vocals" do you mean absolutely none at all, not even faint/distorted/ghostly? The reason I ask is that some dvd players have a "karaoke mode" function, which attempts to remove vocals from commercial recordings. They do this by simply subtracting one channel from the other, using the assumption that most vocal tracks are mixed to be common to both channels. The subtraction is never perfect, though, so there's usually some residual vocal artifacts. And since bass is generally also common to both channels, that gets wiped out, too. Double check to see if your player has such a mode. If it does, I bet you will find that it's enabled. If so, disable it, and you should be good to go.
Dvd player plays avi files on dvd-r but not dvd+rw???
By bradztheman in forum Video ConversionReplies: 1Last Post: 15th Jan 2012, 12:40 -
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 07:46 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Video Noob - how to create dvd for dvd player from avi, flv files..?
By acegap in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 08:10
