  1. After I Rip in Smartripper I get an error in Dvd2Avi: Wav file is not valid, is there a way around this ?
    Regards: Patsym1
  2. hrm....i'm assuming you get the error after dvd2avi extracted the .wav file? i'm also assuming u created the .d2v project file.
    make sure u have the correct settings under audio tab:
    dolby digital = decode
    mpeg audio = demux
  3. Try Vob2Audio, I think this makes a much better wave-file. Nice level on the volume too.
  4. No poopyhead I get the error during dvd2avi extraction usually after 2 to 3 minutes. I have always used Sefy's guide never had this problem before, all settings are correct, even dvd's I've ripped before witout any problems are giving the same error computer locks and then error message. The only thing I have changed is my motherboard.
    Regards: Patsym1
