I made a dvd5 out of a DVD9 with DVDshrink, but removed the wrong audio track.
How do I extract the right audiotrack only and paste it in the video-TS folder and remove the other one?
Wouldn't it be easier just to start over from scratch and do it right this time? I don't use DVD Shrink, so here's how I'd do it.
You don't paste it in the video-TS folder.
To get the right audio, extract it from the original DVD in any one of a number of ways. I might use PGCDemux.
To change audios. Demux all the assets using PGCDemux. Substitute the audio track you want. Reauthor using Muxman (don't forget the chapters, File->Import Chapters (Celltimes.txt)). Open the original DVD with the wrong audio in VobBlanker. Replace it with the one you made with the right audio. Process.
I ask again, don't you think it might be easier for you to start all over? -
Manono is right - much easier and faster to to it again, and do it right.
/Mats
Extracting DTS-HD track with tsmuxer
By rantonio in forum Blu-ray RippingReplies: 3Last Post: 18th Mar 2011, 08:23 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
Extracting The PCM Track from a DVD
By FBI Agent in forum AudioReplies: 2Last Post: 29th Oct 2007, 02:42 -
Help extracting language track from dual audio video.
By ebisoba in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 13:53 -
Extracting 2nd audio track from avis
By guy with a stick in forum AudioReplies: 1Last Post: 18th May 2007, 21:54
