I recently made several data dvds to back up some files including music files and my favorites from I.E.
When I went to put them back on mu computer none of my music files would play.
And all of the URLs in my favorites were gone??
Media player gives the error: "Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file."
And on my favorites if you look at the properties of a favorite link there are two tabs, a General and a web document tab.
The Web document tab vanished on all the links??
Any idea why this happened?
Any ideas if the music files can be fixed?
Thanks for your time, R
What did you use to perform the backup?
Google is your Friend
Backing up HD DVD
By captainzog in forum Newbie / General discussionsReplies: 13Last Post: 21st Oct 2011, 09:49 -
Need help backing up dvd on a mac
By pibrew in forum MacReplies: 1Last Post: 23rd Aug 2011, 16:22 -
Backing up a DVD
By kschwi in forum DVD RippingReplies: 19Last Post: 29th Nov 2009, 09:15 -
Backing up Region 3 DVD
By javajeep in forum DVD RippingReplies: 5Last Post: 28th Jan 2008, 23:55 -
Trouble Backing-Up DVD...
By LCE in forum DVD RippingReplies: 7Last Post: 1st Nov 2007, 00:38
