Results 1 to 9 of 9
    Jan 2007
    Every time i start the process i get the same program error which shuts off svcd2dvd right after the first step, no matter what settings i use. any ideas??
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you post the log file of the run please?
    Jan 2007
    i didnt save it, but im re-doing it one more time and if, or more likely when, the error occurs ill post all the info i get from it. should be about 5 minutes
    Jan 2007
    actually i got a new error message this time, not a windows error message. here is what it said:
    Version: SVCD2DVD 2.1
    Build: 2.1.2474.30185
    Type: System.AccessViolationException
    Source: SVCD2DVD
    Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xe679539bc4bbd8b5.x479d8533828b9 248(xece14591aa1abb99 x50afe96f7df19242)
    at x3284ccece41ee22b.xece14591aa1abb99..ctor(Guid xe423f530b92aa05c, String xd168ac2ed64c4662)
    at x3284ccece41ee22b.xece14591aa1abb99..ctor(String xd168ac2ed64c4662)
    at x3284ccece41ee22b.xd3764d4f1e921081.x3b9d134dac76e 484(xece14591aa1abb99 x50afe96f7df19242, xcbd1127f90d7945f x3146d638ec378671)
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Threading.ThreadHelper.ThreadStart()
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Mmm. Can you reboot and retry. if you get the same error can you report that as you have done this time, but also attach the log file? Log files are kept in the "logs" folder under wherer you installed SVCD2DVD.
    Jan 2007
    I will reboot and try immediately, but the processing alone, which i will only run once over, still takes about 30-45 minutes so itll be awhile. but here is the log ive been getting:
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.1
    Version: 2.1.2474.30185
    Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
    Executable size: 2.86 MB
    Executable size in bytes: 3006547
    Executable CreationTime: 10/10/2006 10:57:38 PM
    Executable LastWriteTime: 12/29/2006 1:37:02 AM
    Executable LastAccessTime: 1/3/2007 10:56:35 PM
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Professional
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Total Physical Memory: 2.99 GB
    Free Physical Memory: 2.22 GB
    Total Virtual Memory: 1.99 GB
    Free Virtual Memory: 1.96 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: To Be Filled By O.E.M.
    Computer Model: To Be Filled By O.E.M.
    System Type: X86-based PC
    Computer Name: KEVIN-PC
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 1
    User Name: KEVIN-PC\Kevin
    ***************************** Processor ****************************
    Manufacturer: GenuineIntel
    Processor: Intel(R) Pentium(R) 4 CPU 2.66GHz
    Description: x86 Family 15 Model 2 Stepping 7
    CPU Speed: 2.667GHz
    CPU FSB: 133MHz
    L2 Cache Size: 0 bytes
    ***************************** Time Zone ****************************
    Time Zone: (GMT-06:00) Central Time (US & Canada)
    ****************************** VIDEO *******************************
    Name: RADEON X800 XT Platinum Edition
    Processor: RADEON X800 XT Platinum Edition AGP (0x4A50)
    Mode: 1680 x 1050 x 4294967296 colors
    Video Ram: 256 MB
    Status: OK
    Name: RADEON X800 XT Platinum Edition Secondary
    Processor: RADEON X800 XT Platinum Edition Secondary AGP (0x4A70)
    Mode:
    Video Ram: 256 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 16.8 GB
    DeviceID: F:
    FileSystem: NTFS
    FreeSpace: 63.1 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <SVCD2DVD DateTime="1/3/2007 4:57:26 PM" Filename="C:\Kevin\Movies\SVCD2DVD\Greys Anatomy 1-4.s2d"><AssetSet><Asset ID="a9845cde-93de-4379-86d1-a0dda943a314" Path="C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10" Filename="Greys.Anatomy.S03E04.HDTV.XviD-LOL.avi" /><Asset ID="e200cf9f-0379-4859-b9a0-67faeb28a838" Path="C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10" Filename="Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi" /><Asset ID="b7f06797-c07d-4996-bd42-789227fd2a36" Path="C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10" Filename="Greys.Anatomy.S03E02.HDTV.XviD.avi" /><Asset ID="05449c98-c1bf-47a6-8e51-a6d705cf2fc7" Path="C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10" Filename="Greys.Anatomy.S03E03.HDTV.XviD-XOR.avi" /></AssetSet><DVDStructure><TitleSet Name="Episode 1" PostCmd="" MenuButtonType="0"><MenuButton X1="40" Y1="239" X2="239" Y2="292" FontFamily="Tahoma" FontSize="28" FontStyle="3">Episode 1</MenuButton><Title Name="Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi" AssetID="e200cf9f-0379-4859-b9a0-67faeb28a838" MplexOffset="0" /></TitleSet><TitleSet Name="Episode 2" PostCmd="" MenuButtonType="0"><MenuButton X1="40" Y1="302" X2="239" Y2="355" FontFamily="Tahoma" FontSize="28" FontStyle="3">Episode 2</MenuButton><Title Name="Greys.Anatomy.S03E02.HDTV.XviD.avi" AssetID="b7f06797-c07d-4996-bd42-789227fd2a36" MplexOffset="0" /></TitleSet><TitleSet Name="Episode 3" PostCmd="" MenuButtonType="0"><MenuButton X1="40" Y1="366" X2="239" Y2="419" FontFamily="Tahoma" FontSize="28" FontStyle="3">Episode 3</MenuButton><Title Name="Greys.Anatomy.S03E03.HDTV.XviD-XOR.avi" AssetID="05449c98-c1bf-47a6-8e51-a6d705cf2fc7" MplexOffset="0" /></TitleSet><TitleSet Name="Episode 4" PostCmd="" MenuButtonType="0"><MenuButton X1="40" Y1="431" X2="239" Y2="484" FontFamily="Tahoma" FontSize="28" FontStyle="3">Episode 4</MenuButton><Title Name="Greys.Anatomy.S03E04.HDTV.XviD-LOL.avi" AssetID="a9845cde-93de-4379-86d1-a0dda943a314" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Documents and Settings\Kevin\Desktop\GA.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="C:\Kevin\Shared" InitialDVDFolder="C:\Kevin\Movies\SVCD2DVD" InitialProjectFolder="C:\Kevin\Movies\SVCD2DVD" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="True" /><Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="ac3" Chapters="Every 8 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="True" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NeroBurner" DVDDrive="TSSTcorp CD/DVDW SH-S182M" NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 349 MB
    file=C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10\Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi
    FormatName=avi
    Num_Frames=60029
    DurationInSecs=2503
    Duration=00:41:43.4
    VideoCodec=mpeg4
    Width=624
    Height=352
    Standard=NTSC (Film)
    BitRate=1171
    AudioStreamCount=1
    Audio1StreamID=[0x1]
    Audio1SampleRate=48000
    Audio1Codec=mp3
    Audio1BitRate=160
    Audio1Channels=2
    AVI2MPG: 3112kbs Full-D1
    16:57:26: Looking for AVI PAR...
    Pass 1/2: Processing Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi
    16:57:27: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    16:57:27: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    16:57:27: libavutil version: 49.0.0
    16:57:27: libavcodec version: 51.4.0
    16:57:27: libavformat version: 50.2.1
    16:57:27: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
    16:57:27: Input #0, avi, from 'C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10\Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi':
    16:57:27: Duration: 00:41:43.4, start: 0.000000, bitrate: 1171 kb/s
    16:57:27: Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 624x352
    16:57:27: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 160 kb/s
    16:57:27: Output #0, dvd, to 'NUL':
    16:57:27: Stream #0.0, 23.98 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, pass 1, 3112 kb/s
    16:57:27: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    16:57:27: Stream mapping:
    16:57:27: Stream #0.0 -> #0.0
    16:57:27: Stream #0.1 -> #0.1
    16:57:27: [mpeg4 @ 0068E248]frame skip 8
    17:04:11: [mpeg4 @ 0068E248]frame skip 8
    17:09:58: [mpeg4 @ 0068E248]frame skip 8
    17:19:56: [mpeg4 @ 0068E248]frame skip 8
    17:37:25: video:948679kB audio:136904kB global headers:0kB muxing overhead 2.219109%
    Pass 2/2: Processing Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi
    17:37:39: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    17:37:39: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    17:37:39: libavutil version: 49.0.0
    17:37:39: libavcodec version: 51.4.0
    17:37:39: libavformat version: 50.2.1
    17:37:39: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
    17:37:39: Input #0, avi, from 'C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10\Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi':
    17:37:39: Duration: 00:41:43.4, start: 0.000000, bitrate: 1171 kb/s
    17:37:39: Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 624x352
    17:37:39: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 160 kb/s
    17:37:39: Output #0, dvd, to 'C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10\Greys.Anatomy.S03E01.HDTV.Xvid-LOL_S2D.mpg':
    17:37:39: Stream #0.0, 23.98 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, pass 2, 3112 kb/s
    17:37:39: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    17:37:39: Stream mapping:
    17:37:39: Stream #0.0 -> #0.0
    17:37:39: Stream #0.1 -> #0.1
    17:37:39: [mpeg4 @ 0068E248]frame skip 8
    17:44:20: [mpeg4 @ 0068E248]frame skip 8
    17:49:20: [mpeg4 @ 0068E248]frame skip 8
    17:59:05: [mpeg4 @ 0068E248]frame skip 8
    18:18:09: video:950570kB audio:136904kB global headers:0kB muxing overhead 2.218365%
    18:18:09: AVI2MPG: done.
    NTSC(Film)->NTSC: demuxing Greys.Anatomy.S03E01.HDTV.Xvid-LOL_S2D.mpg\
    also it seems i did find a post where someone had this same problem, and they said they were unable to fix it by reinstalling any version of the program, but after they did these things:
    The fix:
    I started with removing the SVCD2DVD v2 software, then removed all the programs that were installed after the first SVCD2DVD install.
    Then I went into the Windows registry and removed all traces of not only the SVCD2DVD software but all the other removed software.
    I also removed .Net Frameworks.
    Then I shut down the system to get a full memory dump.
    Restarted the system, installed the other programs that was removed, then installed .Net Frameworks 1.1, and then the SVCD2DVD v2.
    then they say it works. problem is that ive had the program for quite awhile and i cant uninstall every program ive installed since then so i dont know that its an option. also i dont like to mess with Windows registry because i dont know enough to risk messing up my system.
    Jan 2007
    bahhhh i went ahead and uninstalled a bunch of new programs i had installed. then i uninstalled and reinstalled .net framework 2.0. and i got the same windows error after. here is the log this time
    Title: 2.1
    Executable LastAccessTime: 1/4/2007 1:19:56 AM
    Version : 5.1.2600
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Free Physical Memory: 2.55 GB
    Free Virtual Memory: 1.95 GB
    CPU Speed: 2.667GHz
    CPU FSB: 133MHz
    Video Ram: 256 MB
    Status: OK
    Mode:
    Video Ram: 256 MB
    Status: OK
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 18.2 GB
    DeviceID: F:
    FileSystem: NTFS
    FreeSpace: 63.1 GB
    <SVCD2DVD DateTime="1/3/2007 7:21:22 PM" Filename="C:\Kevin\Movies\SVCD2DVD\Greys Anatomy 1-4.s2d"><AssetSet><Asset ID="a9845cde-93de-4379-86d1-a0dda943a314" Path="C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10" Filename="Greys.Anatomy.S03E04.HDTV.XviD-LOL.avi" /><Asset ID="e200cf9f-0379-4859-b9a0-67faeb28a838" Path="C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10" Filename="Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi" /><Asset ID="b7f06797-c07d-4996-bd42-789227fd2a36" Path="C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10" Filename="Greys.Anatomy.S03E02.HDTV.XviD.avi" /><Asset ID="05449c98-c1bf-47a6-8e51-a6d705cf2fc7" Path="C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10" Filename="Greys.Anatomy.S03E03.HDTV.XviD-XOR.avi" /></AssetSet><DVDStructure><TitleSet Name="Episode 1" PostCmd="" MenuButtonType="0"><MenuButton X1="40" Y1="239" X2="239" Y2="292" FontFamily="Tahoma" FontSize="28" FontStyle="3">Episode 1</MenuButton><Title Name="Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi" AssetID="e200cf9f-0379-4859-b9a0-67faeb28a838" MplexOffset="0" /></TitleSet><TitleSet Name="Episode 2" PostCmd="" MenuButtonType="0"><MenuButton X1="40" Y1="302" X2="239" Y2="355" FontFamily="Tahoma" FontSize="28" FontStyle="3">Episode 2</MenuButton><Title Name="Greys.Anatomy.S03E02.HDTV.XviD.avi" AssetID="b7f06797-c07d-4996-bd42-789227fd2a36" MplexOffset="0" /></TitleSet><TitleSet Name="Episode 3" PostCmd="" MenuButtonType="0"><MenuButton X1="40" Y1="366" X2="239" Y2="419" FontFamily="Tahoma" FontSize="28" FontStyle="3">Episode 3</MenuButton><Title Name="Greys.Anatomy.S03E03.HDTV.XviD-XOR.avi" AssetID="05449c98-c1bf-47a6-8e51-a6d705cf2fc7" MplexOffset="0" /></TitleSet><TitleSet Name="Episode 4" PostCmd="" MenuButtonType="0"><MenuButton X1="40" Y1="431" X2="239" Y2="484" FontFamily="Tahoma" FontSize="28" FontStyle="3">Episode 4</MenuButton><Title Name="Greys.Anatomy.S03E04.HDTV.XviD-LOL.avi" AssetID="a9845cde-93de-4379-86d1-a0dda943a314" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Documents and Settings\Kevin\Desktop\GA.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="C:\Kevin\Shared" InitialDVDFolder="C:\Kevin\Movies\SVCD2DVD" InitialProjectFolder="C:\Kevin\Movies\SVCD2DVD" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="True" /><Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="ac3" Chapters="Every 8 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="False" ForceWS="True" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NeroBurner" DVDDrive="TSSTcorp CD/DVDW SH-S182M" NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
    File Size: 349 MB
    FormatName=avi
    Num_Frames=60029
    DurationInSecs=2503
    Duration=00:41:43.4
    VideoCodec=mpeg4
    Width=624
    Height=352
    BitRate=1171
    AudioStreamCount=1
    Audio1Codec=mp3
    Audio1BitRate=160
    Audio1Channels=2
    19:21:22: Looking for AVI PAR...
    19:21:22: ForceWS: VTS will be 16:9
    Pass 1/1: Processing Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi
    19:21:23: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    19:21:23: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    19:21:23: libavutil version: 49.0.0
    19:21:23: libavcodec version: 51.4.0
    19:21:23: libavformat version: 50.2.1
    19:21:23: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
    19:21:23: Input #0, avi, from 'C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10\Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi':
    19:21:23: Duration: 00:41:43.4, start: 0.000000, bitrate: 1171 kb/s
    19:21:23: Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 624x352
    19:21:23: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 160 kb/s
    19:21:23: Output #0, dvd, to 'C:\Kevin\Shared\Grey's Anatomy Episodes 3.01- 3.10\Greys.Anatomy.S03E01.HDTV.Xvid-LOL_S2D.mpg':
    19:21:23: Stream #0.0, 23.98 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 3112 kb/s
    19:21:23: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    19:21:23: Stream mapping:
    19:21:23: Stream #0.0 -> #0.0
    19:21:23: Stream #0.1 -> #0.1
    19:21:23: [mpeg4 @ 0068E248]frame skip 8
    19:28:30: [mpeg4 @ 0068E248]frame skip 8
    19:33:10: [mpeg4 @ 0068E248]frame skip 8
    19:45:33: [mpeg4 @ 0068E248]frame skip 8
    20:01:58: video:948679kB audio:136904kB global headers:0kB muxing overhead 2.219109%
    20:01:58: AVI2MPG: done.
  8. Member guidorobben's Avatar
    Feb 2004
    Netherlands
    Do you have this file "Greys.Anatomy.S03E01.HDTV.Xvid-LOL_S2D.mpg" on your pc or does it have a different name?
    Guido
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Also can you try copying Greys.Anatomy.S03E01.HDTV.Xvid-LOL.avi to say C:\Kevin and then try it on its own - just to see if your path (having a ' in the folder name) is the problem.
