hi there,
i have made vcd's with nero burning rom, however the entire process of making a vcd from a dvd rip is long and a strain on both my hard-disk-drive and cpu.
so in light of this information i was wondering if there was a way to copy my vcd's straight to cd-r like when you copy psx games, if not possible then who has a link to vcd copying guides.
help appreciated, ideas welcome
cheers
moviemadness
the way i know is to copy the .dat files which are the vid files over and then burn the vcd just like you did the first time except instead of mpeg files they are .dat files....
Coping the "DAT" file should be your last recourse when all else has failed.
VCDs are like any other type of CD and can be copied with a simple DAO copier (e.g., the Copy CD functions in Nero, or CDRWin, or Clone CD, etc.)
Regards.
Michael Tam
w: Morsels of Evidence
Handling home made HD recordings
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Mar 2010, 17:03 -
Diffuser home made
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2009, 04:56 -
Home made AVI to FLV
By Eibach in forum Video ConversionReplies: 3Last Post: 6th Dec 2007, 14:25 -
can't copy home made dvdr
By pressthe6 in forum Authoring (DVD)Replies: 20Last Post: 29th Nov 2007, 10:35 -
Copy home-made DVDs to my computer hard-drive
By CdnMark in forum Newbie / General discussionsReplies: 2Last Post: 5th Nov 2007, 23:50
