Can someone help, i've been trying to burn a film but each time i get an error message.
I've tried diffrent tools like imagburn,nero and dvd shrink.
But each time part way through the burning process i get eroor message.Below is the error message i got when i put it through dvd shrink. Hope you can help.
1A23-0609-4030-2333-6402-0097
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:34
Nero API version: 6.6.0.18
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 18e
Recorder: <LITE-ON DVDRW SHM-165P6S>Version: MS0M - HA 1 TA 1 - 6.6.0.18
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : ST320413A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW SHM-165P6S atapi Port 1 ID 1 DMA: On
CdRomPeripheral : UI3463G IEM782O 1.0 ae0emgri Port 2 ID 0 DMA: Off
CdRomPeripheral : UI3463G IEM782O 1.0 ae0emgri Port 2 ID 1 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW SHM-165P6S D: CDRom0
UI3463G IEM782O G: CDRom1
UI3463G IEM782O H: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 28311552 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 159MB (163316kB)
Free physical memory: 33MB (33812kB)
Memory in use : 79 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
3.1.2007
NeroAPI
19:48:50 #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
19:48:50 #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
19:48:50 #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
19:48:54 #4 Text 0 File Reader.cpp, Line 127
Reader running
19:48:54 #5 Text 0 File Writer.cpp, Line 122
Writer LITE-ON DVDRW SHM-165P6S running
19:48:54 #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
19:48:54 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
19:48:54 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
19:48:55 #9 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
19:48:55 #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1997199 (443:49.24, 3900MB)
19:48:55 #11 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO
19:48:55 #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: LITE-ON DVDRW SHM-165P6S, Media type: DVD+R
Disc Manufacturer ID: PRODISC, Media Type ID: R04, Product revision number: 4
Disc Application Code: 0, Extended Information Indicators: 7
19:48:55 #13 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
19:48:55 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1997200 (1997200) = #1997200/443:49.25
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1997200 blocks [LITE-ON DVDRW SHM-165P6S]
19:48:55 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [LITE-ON DVDRW SHM-165P6S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4090265600, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1997200 | lead-out | 1 | 0x41 | 0x00
19:49:03 #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
19:49:03 #17 Text 0 File Burncd.cpp, Line 4122
Cache writing successful.
19:49:03 #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
19:49:03 #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 6x (8,310 KB/s)
19:49:03 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:49:04 #21 Text 0 File Cdrdrv.cpp, Line 8892
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: PRODISC.
Media type ID: R04
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 50 52 4F 44 49 - 53 43 00 52 30 34 04 38 ...PRODISC.R04.8
23 54 37 0F 02 54 6B 02 - 94 63 15 15 0B 0A 08 08 #T7..Tk..c......
01 1C 1E 0B 0C 12 12 01 - 00 00 00 00 00 00 00 00 ................
19:49:04 #22 Text 0 File DVDR.cpp, Line 5876
Drive: LITE-ON DVDRW SHM-165P6S
Book Type request [LO], rev 3: DVD-ROM
Changing the Book Type was finished successfully, return code 0
19:49:04 #23 CDR -1211 File DVDR.cpp, Line 5297
Book Type set to: DVD-ROM
19:49:04 #24 Text 0 File DVDPlusRW.cpp, Line 659
Start write address at LBA 0
DVD high compatibility mode: Yes
19:59:39 #25 SCSI -1135 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x01880000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x03 0xF9 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
19:59:39 #26 CDR -1135 File Writer.cpp, Line 311
Write error
19:59:39 #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
19:59:39 #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
19:59:39 #29 Phase 127 File APIProgress.cpp, Line 276
Generating DVD high compatibility borders
19:59:39 #30 Phase 129 File APIProgress.cpp, Line 276
Generating DVD borders completed successfully
19:59:39 #31 Text 0 File DVDR.cpp, Line 5876
Book Type request [LO], rev 3: DVD+R
19:59:39 #32 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 6x (8,310 KB/s)
19:59:39 #33 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
19:59:39 #34 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 27/07/2006 17:28:33 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Ps i put it through on the lowest speed x6
I constantly have trouble with DVD-RW wearing out. I do daily website file backups and store them on DVD-R and DVD-RW.
Are your discs new or have you been using them for awhile? -
Update the drive's bios ... and try different brand of media .
You can alway's run into problems when the basic's aren't followed .
1: Dvd-r
2: Burn at 4x
3: No more than 4.3gig
4: Not all media is good ... you can get an odd batch turn up under any brand name that's crap .
Console's like + ... but alot of dvd home player's dont .
Rewritable's update each time they are inserted into the pc's writable drive ... a possible place causing issue's with disc's failing . -
I've tried new and used dvd, i also updated my firmware.
Is there any other updates i should make, also i've just put in another 128mb of memory,as i kept on getting pop up saying vitual memory is low, so i was wondering if that could be the problem.
Any thoughts -
Could be the drive is bad. But before you replace it, try cleaning the laser lens. They make a cleaner disc for that, or you can go in with alcohol and a soft cloth and gently clean it.
Media ID = PRODISC.R04
That's not the best DVD+R 16x media to use in a Lite-On 165P6S. As others have stated - try different media. You're in the UK - try some Verbatim from SVP - expecially with a YUDEN 00T03 media id. Any Verbatim DVD+R 16x will be a better match for that drtive however.
DVDRW 2016UI - DVD Rewriter
By DVD-Writeoff in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Sep 2011, 13:18 -
VHS to DVDRW recording with Samsung VR330
By ecc in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jan 2009, 16:53 -
DVDRW not recognized by Windows XP
By bmwracer in forum ComputerReplies: 38Last Post: 11th Sep 2008, 21:33 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 03:54 -
Samsung DVDRW Drive Won't Eject
By 888888 in forum DVD & Blu-ray WritersReplies: 4Last Post: 5th Nov 2007, 20:27
