I just got a new computer, and finished downloading a basketball game, but it says I need a video codec. When I try to play it in Windows Media, the only thing that works is the audio.
File Type: AVI (xvid)
Audio Format: MPEG Layer-3
What codec(s) do I need? Would you be able to link me to where I can download it?
The only player I have right now is Windows Media, what are some others I may need for video playing? Could you please link me to those as well?
You can play everything with VLC, it has all codecs built-in.
But if you would like to use Windows Media Player install latest ffdshow. -
Or just install the latest divx codec.
You can also download and use gspot. Just run gspot, open the file that won't play, and it will show you what codec(s) are needed. Then just download and install the needed codecs.Google is your Friend
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
HELP! Video that says its one codec that its not.?!?!
By doctor37 in forum Video ConversionReplies: 2Last Post: 17th Jan 2009, 13:34 -
Video Codec
By Dave1024 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Apr 2008, 01:46 -
video codec
By ribac in forum Software PlayingReplies: 1Last Post: 8th Feb 2008, 01:09
