I have a movies that probably has all the .rars but no pars.
there is a .nfo, and a .sfv part(13).rars
anything I can do?
cheers
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
If you have all the rars and they are all error free you should be able to extract the movie with any program that can unpack rars. The pars are for repairing corrupt rars.
The .sfv file can give you a high grade of certainty that all rars are error free (if it contains CRC32 checksums for all rar parts).
checkSum+ can open a sfv file and verify the files by comparing the calculated checksums with the checksums listed in the sfv file.
Also, many unrar utilities have built-in checking of the integrity of rar archives; they would report it if they found a part that isn't right. -
I have MacPar delux but if I click one of the .rar parts it says empty.
tried to download checksum+ but just got a web page is computer-speak not a file on the desk top.
the files are:
.nfo
parto1.rar
part13.rar
.sfv
no 'plain' rar.
cheers any idea on how to download the checksum+ ??MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
you need winrar to extract the .rars (current version is WinRAR 3.62) get it here http://www.rarlab.com/download.htm
Install winrar ... go to folder containing .rar files and double click on the first one (ie part1.rar)... winrar will open .... click extract and choose location to save in ... click ok .... all files should now extract and you will have the complete movie in the selected folder.
use quick sfv to verify the .rar files are not corrupt http://www.quicksfv.org/download.html
EDIT: .... just realised you're using a MAC .... not sure if winrar works on MACs .... if not do a search for similar apps for MACs .... any such app will function in a similar way -
EDIT 2 ..... there is a version (winrar) for the MAC using the same link as above ... look in list for RAR 3.60 for MAC OS X
Unfortunately Quicksfv doesn't work on MAC's ... however you only need to use an sfv check app if you suspect the rar's are corrupt -
SFV check applications, if the .rars are corrupt. Here are some that I sometimes use.
Code:http://www.macupdate.com/info.php/id/13622 http://www.macupdate.com/info.php/id/23168 http://www.macupdate.com/info.php/id/12590
In MacPAR deLuxe, try menu Process > Unrar archive (Cmd-U), then open the foo.part01.rar file.Originally Posted by rotuts
As I may have mentioned before, there are two ways of naming segmented rar files; one of them is without 'plain' rar file.Originally Posted by rotuts
Just follow the link that says "Download now" on the page behind my link or one of dwm2287's links.Originally Posted by rotuts
After downloading, drag-and-drop the sfv file to the checkSum+ application icon. It will start calculating, and give an "All OK!" message when it has verified all files to be correct.
PS3 Playing issues when assembled with VOB2MPG
By netvet in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Apr 2012, 09:26 -
PS3 Playing issues when assembled with VOB2DVD
By netvet in forum Media Center PC / MediaCentersReplies: 3Last Post: 22nd Apr 2012, 09:09 -
How to Convert RAR HTML Files Into A Movie File
By raven120461 in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 12:35 -
rar files w no pars
By rotuts in forum MacReplies: 2Last Post: 8th Aug 2008, 22:30 -
Movie in a .rar file 99.9% complete, is there a way to extract it?
By dexter30 in forum Newbie / General discussionsReplies: 13Last Post: 10th Feb 2008, 08:55
