Hey people i just wanted to know is it possible to make a menu in photoshop (design a still background picture) and also the buttons on it and then add the file to TSUNAMI-MPEG DVD Author PRO
Or can i only make the background and would have to add buttons seperate with TSUNAMI-MPEG DVD Author PRO?
So can someone please let me know if its possible for me to make a menu in photoshop and import that into TSUNAMI-MPEG DVD Author PRO so it becomes a proper menu.
Thanks Chana
"Yes you can!"
That dont help me out alot m8 can u elaborate on that a little and show me how to please?? -
I have TMPGEnc DVD Author v1.5 (I don't use it any more - I use DVDLab Pro) and that can import PSD files - but I've never used it and don't know if it will recognise any layers that are present; if, that is you can have layers in a PSD file - I can't remember.
Simple answer - give it a go and see.
EDIT: I tried it out and the layers in a PSD file aren't recognised by TDA v1.5. However, DVDLab does recognise layers in the PSD file.
If TDA won't do what you want, consider DVDLab (or the Pro version) as that will definitely recognise the layers - I use PNG files though...
There are other authoring tools that recognise layers too - check them out the "Tools" section by clicking the link to the left.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
By the way this is the guide: https://forum.videohelp.com/viewtopic.php?t=318702
Picture as Menu Background in Adobe Photoshop
By boofer in forum Authoring (DVD)Replies: 3Last Post: 16th Oct 2008, 01:41 -
Motion Menu's - Where Do I Start? In Photoshop?
By EViS in forum Authoring (DVD)Replies: 11Last Post: 21st Aug 2008, 22:35 -
HOw do you creat e-com website?
By snickdog in forum Off topicReplies: 5Last Post: 3rd Dec 2007, 20:33 -
How to create DVD menu buttons in Photoshop w/text only highlighting?
By rbatty11 in forum Authoring (DVD)Replies: 5Last Post: 30th Nov 2007, 19:58 -
Need a Guide/Tutorial for Sonic Scenarist and Menu creation with Photoshop
By src2206 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2007, 04:04
