I recently am having problems with my JVC player rejecting my DVD's that it played before,
it says no disc. any help would be great!
Thanks hmdot
If they are commercial discs, then the player is faulty. If they are copies, then you have bad discs. Most likely cheap media, or a media that the player doesn't like.
Google is your Friend -
The disc are Verbatim 16xDVD-r
I have had very good luck with the disc in the past, do you think I need to change? -
You can try looking up your player in the DVD Players section and see what brand/types of media other have had success using.
Other than that, I would try a different brand/type of media. Verbatim are usually reliable, so it could be you have/had a bad spindle. It is also possible your player is at fault. The laser loses power with age/use and the first discs to suffer are recordable discs.Google is your Friend
JVC HM-DH40000 as a VHS player
By zorankarapancev in forum RestorationReplies: 37Last Post: 22nd Aug 2020, 16:40 -
Problems with JVC HR S6900U VCR.
By Video converter in forum Newbie / General discussionsReplies: 0Last Post: 9th Nov 2010, 14:31 -
Pinnacle 9 - JVC cam problems
By Maarten in forum Capturing and VCRReplies: 3Last Post: 19th Jan 2009, 17:38 -
JVC DR MV-7 reading problems after hacking
By PTCAL in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Feb 2008, 04:47 -
why my jvc player is lock ?
By meeya in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Jun 2007, 13:27
