What is correct FPS 'Frame per second(Motion) settings in QuickTime 6.1 PRO when export MOV to AVI? From movie info: static FPS = 4 and a little differs when playing. What FPS should I set: from mov info, or from predefined QuickTime profle: 'best', 8, 10,... etc ? As far i understand, the FPS should correspond to FPS of mov source?
The files are video tutorial, its just consecutive captured Screenshots demonstrating the application. There is no needs for high FPS. Some have even 2FPS. So, to use the same rate as shown in static FPS info?
yes - use same ....
after it is in avi - IF you are going to make a dvd or something -- you will have to change it -- but dont let QT change the speed ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
should I use exact fps rate that specified in 'static' movie, even fractional number (1.99)?
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Correct Settings for 16:9 Anamorphic DVD?
By helplessandlost in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2010, 11:47 -
Correct Settings in Image Burn for HD-DVD?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 17th Jan 2009, 17:01 -
Correct settings for encoding video for the 'new' YouTube format?
By Captain Satellite in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2008, 17:45 -
quicktime animation codec - fps problem
By phpmysql348 in forum Video ConversionReplies: 0Last Post: 28th May 2008, 06:36
