    Dec 2006
    Sorry, I know I've asked for help before, but now I'm back with more trouble. So I finished designing my dvd, put together the menu, movies (in NTSC format), etc. But when I compile DVD, the software gives me an error message, "VOBU end address is recorded incorrectly. Process is terminated". Why is this happening? Thanks in advance for helping me out.
    Below is a screen capture of the exact compiling log.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    You will need to demux the VOB files when you import them. Before you import anything go to project/project properties/options and set it so DLP will demux for you. Alternatively use Rejig in file mode.
    He's a liar and a murderer, and I say that with all due respect.
    Dec 2006
    Thanks steveyan, so does this mean that I have to demux the VOB files and then put the demuxed files onto the movie tracks? (sorry, sounds dumb...)
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Yes, when you demux you will have video (m2v) and audio (ac3,dts etc) in seperate files. Import these into your movie timeline type thingy.
    Dec 2006
    Ugh, I'm beginning to get frustrated. This time, there's no error message, and the log says compiling is done. But no dvd files is actually created and the dvd AUDIO_TS and VIDEO_TS folder is still empty, but there's a file vts.bin being created. What's the program doing and how can I actually save and burn the dvd?
  6. Originally Posted by Adeline
    reset default settings and see what happens. There is probably a cnf file
